NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
Create vertical dashed line over the graph (not cursor)
已解决!
转到解答
Hi all,
Recently, I came across a problem that creating a vertical dashed line over the graph. I searched the relative information in the discussion forum, but I can't find the solution. A lot of people are talking about creating the cursor, but my target is not a cursor.
My problem is... I would like to create a vertical dashed line to the graph, which waveform has already there. The x and y values of the line can be controlled by the controller box. Any help is appreciated!! Thank you in advanced.
Tinam
0 项奖励
1 条消息(共 5 条)
4,651 次查看
Hello Tinam,
you could use the "XScale>>Marker Values"-Property to add a vertical line to your graph.
Regards
MY
0 项奖励
2 条消息(共 5 条)
4,630 次查看
Hello My Ni:
Thank you for your response.
Do  you mean use the property node of the graph?
But I can't find the "Maker value" you mentioned. Could you please give me more information? Thanks again.
Tinam
0 项奖励
3 条消息(共 5 条)
4,588 次查看
解答
接受人 tinam
What LabVIEW version are you running?
I use LabVIEW 8.6. You will find the property in attached screenshot.
Regards
MY
0 项奖励
4 条消息(共 5 条)
4,584 次查看
Hi MY,
Thank you very much! It is a kind of way to create a vertical line, but the line is not highlighted. Is there any way to make it highlighted?
Tinam
0 项奖励
5 条消息(共 5 条)
4,560 次查看
