NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
Labview 2014版CIN函数为啥找不到
已解决!
转到解答
labview2014版本,代码接口节点(CIN)为什么在互联接口子选板“库与可执行程序”选板找不到,是不是需要安装其他模块?
0 项奖励
1 条消息(共 3 条)
4,530 次查看
Hi Alenter,
According to THIS CIN is no longer support in LabVIEW you can use Call Library Function Node.
Hope it helps.
Amit
CLAD
0 项奖励
2 条消息(共 3 条)
4,514 次查看
解答
接受人 alenter
alenter
If you still are going to use old CIN instead of standard DLL you may take a look at this post: http://forums.ni.com/t5/Discussions-au-sujet-de-NI/Ins%C3%A9rer-du-code-C-dans-un-VI-LabView/m-p/314... There I have explained the steps to get CIN technology working in new LabVIEW versions.
0 项奖励
3 条消息(共 3 条)
4,425 次查看
