06-08-2012 10:05 AM
Hi Gaurav_Singla,
Sorry for the late reply, I was out of town and just saw this.
Good news is, I know exactly what you need to do. Look at this: FPGA Personality Example: Variable Duty Cycle & Frequency PWM generation and measurement
Should be what you need!
 ni_2012
			ni_2012
			06-08-2012 11:57 AM
I am unable to install FPGA Based I/O tools for VeriStand 2011. I tried placing the folder in program files/labview 2011. It goes through the installation but it does not install. After the process is completed, Error 7 pops up. Any suggestions to solve this issue will be appreciated.
 ni_2012
			ni_2012
			06-08-2012 11:59 AM
Cont from the previous post - Issues about installation on VeriStand 2011
I forgot to add this in my previous post - When I extract files, it asks me for a password for certain files.
06-08-2012 12:16 PM
You should not extract the files to program files. This is an installer. Just extract it to a temp location like your desktop and run the installer VI. I've made a video of this process to be clear: http://screencast.com/t/kCdoLDyhd
 ni_2012
			ni_2012
			06-08-2012 12:28 PM
Hi Stephen,
Thanks for the quick response.
I followed the whole process in your video.Still after installation is complete, VeriStand FPGA tools are not installed and I get error 7. Did you try the installation on VeriStand 2011?
06-08-2012 12:31 PM
Can you post the full text of the error?
06-08-2012 12:32 PM
Also, can you verify you have LV FPGA installed? (it is required)
 ni_2012
			ni_2012
			06-08-2012 12:42 PM
Error 7 occurred at List Folder in NI VeriStand FPGA Interface Tools Installer.vi
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488: Nonexistent GPIB interface.
C:\Documents and Settings\tulauser1.TRAVERSE\Local Settings\Temp\Temporary Directory 1 for NI VeriStand FPGA Interface Tools 2010+ 1.1.2.zip\NI VeriStand FPGA Interface Tools 2010+\Files\2010
I have FPGA module installed
06-08-2012 12:50 PM
You are running the VI from inside the zip file. Please be sure to follow the video and extract the folder to a temporary directory before running the installer VI.
 ni_2012
			ni_2012
			06-08-2012 02:48 PM
Hi Stephen,
I did everything as outlined in your video. Still I get Error 7. I will try to re-intall labview and will try installing FPGA tools.
