NI Linux Real-Time Discussions
launch two rtexes on linux rt
Is there a way to run two rtexe on linux rt.Startup is not required.
any advice would be helpful.
(5,067 Views)
Accepted by himire
Hi himire,
Unfortunately having two side-by-side LabVIEW RTEXE's running at the same time is not supported today, but you can have one RTEXE call multiple VIs. Am I correct that what you're looking for are both to be LabVIEW-built executables? Can you please explain a bit more the functionality you are looking for?
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(4,601 Views)
hi,
Thanks for your reply.
I wonder if rt can launch two labview-built executebales before.As your word,one RTEXE call multiple VIs can work this out.
Thanks.
(4,601 Views)
