NI Package Manager (NIPM)
Automate the install of DAQmx 18.5
Hey everyone, I'm trying mimic the functionality of clicking "Install" in the GUI of NIPM for any specific product via the command line. For example, after installing NI Package Manager, how would I install NI-DAQmx 18.5 64bit?
I'm new to this and I'm trying to automate software installation.
Message 1 of 11
(5,743 Views)
Accepted by topic author Taxman414
This is how I did it:
1) Install NI Package Manager:
start /wait NIPackageManager21.3.0_online.exe --quiet --accept-eulas --prevent-reboot
2) Launch NI Package Manager and browse to the title\version\bitness you want. Click Install and leave the "wizard" open.
3) Get the name and URI of the feed that NI Package Manager temporary added for that package
cd "C:\Program Files\National Instruments\NI Package Manager\"
nipkg feed-list
4) Search for the package name, version, and bitness
nipkg list | findstr "runtime"
5) Build your script. (You can close NIPM)
cd "C:\Program Files\National Instruments\NI Package Manager"
:: Add feed from step 3. Make sure your name doesn't have any spaces.
nipkg feed-add --name=ni-labview-2019-runtime-engine-x86-2019-released        https://download.ni.com/support/nipkg/products/ni-l/ni-labview-2019-runtime-engine-x86/19.0/released
nipkg feed-add --name=ni-labview-2019-runtime-engine-x86-2019-released-critical       https://download.ni.com/support/nipkg/products/ni-l/ni-labview-2019-runtime-engine-x86/19.0/released-critical
:: Get list of packages from feed.
nipkg.exe update
:: Install the package name, bitness and version from step 4. Allow and accept EULAs. Syntax is tricky.
nipkg install ni-labview-2019-runtime-engine-x86:windows_all=19.0.2.49152-0+f0 -y --accept-eulas
Message 2 of 11
(5,700 Views)
You can also use NI Package Builder to build a Package Installer that can be call without user interaction. The Package Installers will install/update NIPM if needed and then install your selected packages. This allows you to keep a local copy of all the packages so you do not need an internet connection to NI to do the installation. To silently run the built install.exe add these flags to the command prompt call --passive --accept-eulas. --prevent-reboot will suppress the NIPM reboot message if your installation needs it. I tend to add shutdown.exe -r -t 00 after a message and pause to my installation batch files to have users reboot afterwards.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
Message 3 of 11
(5,683 Views)
Yet another option is to:
  1. Download the online or offline installer for the product, such as: https://www.ni.com/en/support/downloads/drivers/download.ni-daqmx.html#409845
  2. Follow the automation instructions from the NIPM manual here:
    https://www.ni.com/docs/en-US/bundle/package-manager/page/automate-installer.html
Message 4 of 11
(5,677 Views)
These are great alternatives but I have zero desire to host an internal repository for NI packages.
I'm setting out to "mimic the functionality of clicking Install in the GUI."
Also, not all packages have an online installer. Case in point: DAQmx 18.5.
Message 5 of 11
(5,675 Views)
The Package Installer is a stand-alone installer, no feed/repo needed. Just a folder with files like any other unzipped installer
Bill Eisenhower
Message 6 of 11
(5,667 Views)
Very cool. As an example, how would you approach my original issue using NI Package Builder/NIPM?
Message 7 of 11
(5,660 Views)
Basically this or from the NI Package Builder Manual
You will need to have the packages you want to build into the installer already installed along with NI Package Builder. Then you create the Package Installer adding the package(s) you want to have installed. When you build the installer it will get all the dependencies needed as well. You can use the set package to always install so in case someone runs without the automation flags, they will be able to miss clicking the item in the installer
Bill Eisenhower
Message 8 of 11
(5,652 Views)
Just to clarify: If you have either an online and offline NIPM-based installer that you want to take the installation defaults of, you don't need to use NI Package Builder. You can just run that online or offline installer with the command-line I posted above from the manual - in either case, it will run as-is without setting anything up.
Using NI Package Builder is more work, but is a good choice if you want to create your own custom installer containing whatever set of packages you want. Note that NI Package Builder creates an offline installer that is exactly the same as the offline installer you'd download for a product, like DAQmx.
Message 9 of 11
(5,639 Views)
This is a great hint!!! Now, is it possible to do it without clicking? I mean it is clear to me that NIPM can find feed automatically and probably add it temporally when you open wizard. How can I automate it?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 10 of 11
(5,136 Views)
