2 | |
2 | |
1 | |
1 | |
1 |
It would be a big convenience if, when you are configuring a TestStand Deployment, the Workspace automatically populated with the current workspace that was open when you try to deploy. While not a major inconvenience, it is somewhat of a hassle to go and select the same file every time, especially if you are making small changes to test a system.
I'm declining this due to lack of community support.
