 MimiKLM
			 on
		10-12-2013
		03:23 AM
			3 Comments (3 New)
			MimiKLM
			 on
		10-12-2013
		03:23 AM
			3 Comments (3 New)
It's a very likley to happen that during the test the one LV module is called more than one time. As well it is very likely to happen the during the development we have to modify the module itself by changing the input/output from the VI or the connector pattern of the VI. If we have to Reload VI Prototype in one or two instances it's fine but when the step is in more than two or three places it is very painfull to update all of them.
So, I'm proposing to extend the Step Settings-->Module menu by adding the button with action Reload VI prototype in all instances.
See Warren's post
