NI TestStand Idea Exchange
kent.wedeking
TestStand Deployment Pre/Post Build Actions
Status: Under Consideration
Considering this for NIPB
All the major IDEs I use (LabVIEW, LabWindows/CVI, Visual Studio, etc.) support specifying post build actions as a part of the deployment.
TestStand does not.
Since the TestStand Deployment Utility (at least as of TestStand 2019) does not implement any kind of signing implementation, I'm resorting to manually signing my installers with my official signing certificate after the fact.
2 Comments
bienieck
Active Participant
I think NI plan is to get rid of this tool and replace it with NIPB where you can configure what you need. See this: https://forums.ni.com/t5/UKTAG-UK-Test-Automation-Group/UKTAG-Meeting-6-Agenda/m-p/4111853#M55
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
HarshaBhushan
Status changed to: Under Consideration
