NI TestStand
17306; Unknown variable or property name.
when I run the sequence, usually it's OK, but sometimes, it will rise up a error "Unknown variable or property name 'RunState.Root.Locals.UUT'." and I really can't find it in the Variables.
(858 Views)
This can occur when you don't run with the proper process model.  This is why I hesitate to use RunState.Root in any of my expressions.  Seems like a bad idea.
When you run TestStand without the process model this is called Interactive Execution.  You can read more about it here:https://www.ni.com/docs/en-US/bundle/teststand/page/interactive-executions.html
Running in interactive mode give you a different Root and therefore different variables at the root.
It looks like you are using a modified Batch Model based on your image.  Did you remove that variable?
Can  you describe where you are calling RunState.Root.Locals.UUT?  Is it in a callback?  Main Sequence.  Some other Sequence file?
Also, in your image can you expand Locals and do you see UUT?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(835 Views)
