NI TestStand
Access System.IO.Ports with .NET Module
Using mscorlib Assembly in the module, I don't see the selection for System.IO.Ports.  Trying to use with a .NET SerialPort.  Has anyone had success in using within a sequence directly or do I need to create a wrapper DLL for this?
(2,523 Views)
Came across the need for this again.  Dropping in a reply to see if anyone had a solution to this issue.
(2,281 Views)
Accepted by testergi
It is possible as shown below,  you've been looking at the wrong dll, you need to select System.dll
Santhosh
Soliton Technologies
(2,271 Views)
Thanks @santo_13.  I actually found it soon after sending the last post.  Thanks for the response. 🙂
(2,264 Views)
