Accessing Strings: Teststand - LabWindows, IVI
Hello all,
I'm trying to initialize a driversession with a logicalName which is stored in a teststand string variable. Please have a look at the following code fragment. s_PMI_init(ViRsrc logicalName, ViBoolean idQuery, ViBoolean resetDevice, ViSession *vi) is a function of my Custom Class Driver, which I loaded dynamically. Has anyone an idea why the initialization fails? I think it's a simple mistake but it drives me mad...
ViRsrc * logicalName = NULL; //char *
TS_PropertyGetValString(data->seqContextCVI, &errorInfo, "Step.LogicalName", 0, &logicalName);
//MessagePopup("Info", logicalName); //shows right logicalname
s_PMI_init( "drvsession", FALSE, FALSE, &session ); //works
s_PMI_init( logicalName, FALSE, FALSE, &session ); //doesn't work why?
Thanks in advance
7even
(3,999 Views)
You seem to be trying to get the string "drvsession" from a TestStand step which has a property call LogicalName.
eg Step.LogicalName = "drvsession"
Is this a Custom Step Type you are using?
What version of TestStand are you using?
Regards
Ray Farmer
Regards
Ray Farmer
(3,997 Views)
You're right. It's a custom Step Type and the code fragment is from a module which is called during runtime (Post-Step). I'm using Teststand 4.2 and LabWindows 8.1.
(3,990 Views)
make sure you are passing a valid SequenceContext into the function to use in
Also check what the error is returning from TS_PropertyGetValString.
But seeing as you are using TS4.2, why dont you pass the LogicalName direct to the function. then you dont need to use TS_PropertyGetValString
Regards
Ray Farmer
Regards
Ray Farmer
(3,975 Views)
Accepted by 7even
Here is a snipet of passing the LogicalName direct to the function:
    // This example test module aquires the instrument session by name.  Provided that
    // another reference to the session exists, this module does not recreate or
    // reinitialize the session.
void __declspec(dllexport) __stdcall ConfigureDMMForVoltageMeasurements(const char *logicalName,
        short *errorOccurred, long *errorCode, char errorMsg[1024])
    int error = 0;
    ErrMsg errMsg = {'\0'};
    ERRORINFO errorInfo;
    ViSession   handle;
    CAObjHandle session = 0;
       // get a reference to the session
    tsErrChk( SM_GetSession(logicalName, &session, &errorInfo));
        // get the driver handle (you don't need to release it)
    tsErrChk( SM_GetHandle (session, NULL, SMConst_ClassDriver,
                          &handle, &errorInfo));
        // call the instrument as much as you want:
    errChk( IviDmm_ConfigureMeasurement(handle, IVIDMM_VAL_DC_VOLTS, IVIDMM_VAL_AUTO_RANGE_ON, 0.001));
You can find this example in \TestStand 4.2\Examples\SessionMgr\CVI\
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,969 Views)
