NI TestStand
Accessing properties of a sequence file from labview
I want to produce a report based on the sequence file data to alleviate my software documentation needs which need to be in a specifi format. In order to do this, I want to write a labview program and grab the various teststand sequence info paramters and put them into a specific format.
Most of the labview tools for testatnd require a sequence context to operate.  Is there a way to do this without opening the entire teststand appliaction and laoding a specific sequence ??
(4,172 Views)
Accepted by id
This seems to work for me.  Let me know if you have questions.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,165 Views)
Accepted by id
Thats exactly what I needed - ThanksSmiley Happy
(4,160 Views)
