09-11-2015 08:15 AM
I want to produce a report based on the sequence file data to alleviate my software documentation needs which need to be in a specifi format. In order to do this, I want to write a labview program and grab the various teststand sequence info paramters and put them into a specific format.
Most of the labview tools for testatnd require a sequence context to operate. Is there a way to do this without opening the entire teststand appliaction and laoding a specific sequence ??
Solved! Go to Solution.
09-11-2015 11:48 AM
This seems to work for me. Let me know if you have questions.
09-11-2015 01:07 PM
Thats exactly what I needed - Thanks![]()
