Active X to generate SEQ file from excel Macro in VBA
Hello, I'm trying to generate automatically from excel table sequence files. For the moment I recreate sequence file structure with my own functions. But sometimes teststand does not recognise the file generated by my macro. I would like to know if it exists libraries (active X or something like that) that are usable in VBA to create sequences files and adding step in them. And if it exists, how to implement it? Thanks for you help 🙂
(1,000 Views)
In this link You can find an instructions how to create Sequence File Using the TestStand API.
Here is one for adding Step. Also information about Sequence files, maybe You will get something new from there.
Regards.
(961 Views)
