NI TestStand
Adding SequenceCallModule to Steps
I am new to TestStand and I am trying to programmatically a SequenceCall into a step in C#. I am able to create new steps with:
Step step = engine.NewStep("Sequence Adapter", "SequenceCall");
And add them with:
seq.InsertStep(step, 0, StepGroups.StepGroup_Main);
I have a SequenceCallModule that I loaded my path into.
SequenceCallModule SMod = (SequenceCallModule)step.Module;
SMod.SequenceFilePath = path;
How do I associate this module with my step so when I insert my step the sequence call will be in my main sequence?
Let me know if you need any further information or clarification about my question. I am new to TestStand.
(2,554 Views)
You should check out the shipping example on this topic:
%TestStandPublic64%\Examples\TestStand API\Building a Sequence Using API\DotNet
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,537 Views)
Accepted by AlexKB
This was taken from an NI Week presentation:
Create SeqCallStep:
▪RunState.SequenceFile.GetSequenceByName("MainSequence").InsertStep(RunState.Engine.NewStep("","SequenceCall"),Locals.loopindex,StepGroup_Main)
Note: locals.loopindex is a variable added so they could loop on adding a lot of steps.  It looks like you're almost there, you just need to add something like SequenceFile.GetSequenceByName("MainSequence")
so that it will go in the right place.
Source:
https://s3.amazonaws.com/v3-app_crowdc/assets/7/7b/7b1430895fcc48c2/1700Ochoco1033_0522_113930.origi...
(2,523 Views)
Thank you.
Fixed it.
(2,501 Views)
