Batch model two different Squences
Hi
How do i run two different Squences file using the Batch model?
Help share your knowlegde
(2,727 Views)
If Each UUT has a different serial number, then your are safe, what I have done is to have one subsequence in the main sequence for Each possible model that could run in the tester. Each subsequence has a precondition which must match the header of the UUT serial number.
(2,715 Views)
