11-21-2011 03:14 AM
Hi
How do i run two different Squences file using the Batch model?
11-21-2011 11:55 PM
If Each UUT has a different serial number, then your are safe, what I have done is to have one subsequence in the main sequence for Each possible model that could run in the tester. Each subsequence has a precondition which must match the header of the UUT serial number.
