Calling a sequnce from within the current file
Is there any advantage/disadvantage to calling another sequence from within the same seq file ? I have a UUT that has test within tests...within tests. Should I create seperate seq files ( then call them)or one seq file that has each of these within it ?
(3,084 Views)
I've had several sequences in one sequence file and had no trouble calling any. It is convenient to have it all in one file. However, it is not very practical to re-use any of the sequences for another project. I usually put any re-usable sequences in a different file, to be called by multiple projects. Hope this clears it up.
- tbob
Inventor of the WORM Global
(3,084 Views)
Thanks TBOB. If I use one of the Operator Int shipped with TS 3.0, can I run one of the subsequnces as an individual tests if I have it saved within the same file ? ie If I have a single file with a number of sub seq. can I go in and select just one to run ?
(3,084 Views)
Yes. You can specify any seq within a file containing several seqs. Just try it.
- tbob
(3,084 Views)
