The debug license provides permission to install the specified software
on one additional computer. This can be used for debugging an
existing application on this deployment machine, as long as you have
previously purchased a development license for another machine.
Thus, if you have a development copy license, you can install your
TestStand development software on the debug license computer. You
must remember to use the debug serial number when it asks for a serial
number during the installation.
If you only activated the license on the development CD, but did not
install the development software, the TestStand Sequence Editor will
not be available on that machine. With a deployement license,
only the TestStand engine was installed. This would explain why
you are not seeing the main TestStand execution file (TestStand.exe).
So in order to solve your problem, you will need to install TestStand
and LabVIEW software. If you have installation CDs for TestStand
3.1, you can use it. If you do not have a CD for TestStand 3.1,
you can download the evaluation version
here,
and then use your license to activate it. For LabVIEW 7.1, we do
not currently offer a evaluation version download, so you will need to
install it from a CD.
If you do not have a LabVIEW 7.1 CD, you can contact the Sales
Department at (888) 280-7645. Explain to them your situation of
having a license but needing the CD for installation.
I hope this clears things up for you!
Andrew W. || Applications Engineer
