NI TestStand
Can't write to TestExec.ini
Things like the list of recently opened files and files opened last time the UI was run are saved to that file. Thus it is saved every time the UI is run. You might want to save it to the public documents directory (i.e. on Windows 7 somewhere underneath C:\Users\Public\Documents ).
-Doug
Message 11 of 15
(996 Views)
The Default location is C:\ProgramData\National Instruments\TestStand <Version>\Cfg.  Is there a reason why it is not at the default location?
Message 12 of 15
(989 Views)
-Doug
Ok, this sounds like a good idea. I'll try to change config files under public documents directory. Actually i have permission problems with test report saving as well. So i should place config files and report files under public directory.
Message 13 of 15
(984 Views)
It might not be necessary and this is only a precaution to prevent my deployment to mess up with other deployments which might be already installed on same computer.
E.g.. Deployments from different suppliers may interfere with each other.
Message 14 of 15
(983 Views)
If you are changing config directory of this deployment, the other deployments will still use this other config directory.  Unless you are doing something to temporarily change it then change it back.
Message 15 of 15
(978 Views)
