06-29-2011 09:11 AM
Things like the list of recently opened files and files opened last time the UI was run are saved to that file. Thus it is saved every time the UI is run. You might want to save it to the public documents directory (i.e. on Windows 7 somewhere underneath C:\Users\Public\Documents ).
-Doug
06-29-2011 01:20 PM
The Default location is C:\ProgramData\National Instruments\TestStand <Version>\Cfg. Is there a reason why it is not at the default location?
06-29-2011 09:15 PM
-Doug
Ok, this sounds like a good idea. I'll try to change config files under public documents directory. Actually i have permission problems with test report saving as well. So i should place config files and report files under public directory.
06-29-2011 09:19 PM
It might not be necessary and this is only a precaution to prevent my deployment to mess up with other deployments which might be already installed on same computer.
E.g.. Deployments from different suppliers may interfere with each other.
06-30-2011 09:12 AM
If you are changing config directory of this deployment, the other deployments will still use this other config directory. Unless you are doing something to temporarily change it then change it back.
