NI TestStand
Clear Previous Step Result
Hi...
I have this vi which measures the voltages of a certain board.
I used multiple numeric limits as a step type.
So for example.
Measurement 1
Measurement 2
Measurement 3
I am using this step for my testing for quite sometime. Recenly a new option added
to the board that the operator can tune the voltage when it is out of specs,
So how do i clear the results of Measurement 2 for example when I add up another step to
instruct the operator to tune the voltage before I redo the test again.
Thanks.
(3,185 Views)
I would search the Locals.ResultList for "Measurement 2", save the index, and remove it via the index from the ResultList
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,162 Views)
Hi
here is an addtional example for accessing the ResultList
juergen
--Signature--
(3,155 Views)
