Copy and rename files………..
I would like to copy and rename files using variable names with in a loop.
The source file is the same name but the destination file will vary depending on the loop.
I have Test stand 2.0.1 and windows 98
I have tried a batch file which will run and do the needful but Teststand will return an error and the DOS window will stay open.
How beat can I do this?
Simon
(4,598 Views)
QW123z,
Are you running the batch file using the call executable step?
Why are you using a batch file rather than just the DOS "copy" command?
How are you passing your variable names?
What error are you getting?
Josh W.
Certified TestStand Architect
Formerly blue
(4,585 Views)
Note that you could also use a DLL step to directly call CopyFile in kernel32.dll.  It's CopyFileA or CopyFileW on w2k and up. Its probably CopyFile in Win98, but I'm guessing.
(4,579 Views)
Thanks for the replays.
I will try the kernel32.dll route a try.
To replay to Josh W.
            Yes
            Batch file works where as “Copy” is not recognised!!
A message stating there was an error in "Post".
Attached is the batch file and the sequence step.
What do you suggest as the best route?
Thanks for the help
Simon
(4,546 Views)
