NI TestStand
Custom serial number
I'm new to TestStand and I'm sure this is an easy question. I'm using a custom serial number VI in testStand to, well, get serial numbers. I understand how to modify the PreUUT callback to use my VI, however, how do I programmatically get that number to show up in the filename? I'm sure there must be some property that needs to be set, but after much searching, I have not been able to discover that.
Please advise.
Thanks so mcuh.
(1,192 Views)
The serial number you read from the custom VI should be transferred to parameters.serialNumber.
You can use a statement step and add parameters.SerialNumber = locals.serialnumber ( assuming your VI returns serial number gets stored in locals.serialnumber). Thats it for the reports.
FYI...parameters.continuetesting decides if the sequence has to continue or stop testing.
Ravi
(1,160 Views)
Hi Ravi,
Thanks for this input. I got everything working based on your suggestion.
Cheers,
(1,155 Views)
