Customize Result Processing Plug-In
I am developing custom results processing plug-in. I need to provide specific configuration that will be used within plug-in.
I used Model Plugin - Configure Standard Options and developed VI where I can enter my parameter value.
Further I need to create variable in Parameters.ModelPlugin.PluginSpecific.Options.MyVariable, that will be available in Model Plugin - UUT Done where I plan to use it.
Could you provide by step instruction on how to implement this?
(3,395 Views)
no one knows or not clear explanation?
(3,361 Views)
Accepted by Levon
Please refer to Best Practices for NI TestStand Report Generation and Customization for step by step instructions on creating a result processing model plug-in with required options.
As for adding plugin options, you can either customize the type def (MyCompanyName_MyNewResultProcessorOptions) or use an expression to create properties run-time and assign default values to them:
Parameters.ModelPlugin.PluginSpecific.Options.NewSubProperty("<name>",PropValType_<Type>,False,"",PropOption_DoNothingIfExists)
Hope this helps!
(3,329 Views)
Thanks. It workd!
(3,325 Views)
