01-17-2013 04:56 AM
I'm trying to understand the teststand communication with databases and I have a general question.
Lets say I'm working with teststand and I'm connected to my database.
If while sending my reports the server crashes , now my ATE still working with test stand and creates reports.
Is there any stack or other model that saves my reports and when the server is back online it's automatically sends the saved reports ?
01-17-2013
02:28 PM
- last edited on
10-20-2024
05:36 PM
by
Content Cleaner
Hi Kobi,
There is currently not a feature to store data and log it after a connection error occurs. however, if you are using TestStand 2012, you can use the offline result processing feature to achieve something similar. Using this method, your results will be stored in a compact binary format, which can later be converted to readable results by the offline results processing utility (through report generation or database logging).
For more information on using the offline results processing feature of TestStand 2012, refer to the TestStand help:
TestStand Offline Results Processing Utility
When using this method, new, unprocessed results will appear in the inbox section of the Offline Results Processing Utility, and will be moved to the outbox location once processed. However, if an error occurs during report generation or database logging, the inbox file will remain so that you can retry. This will ensure that no data is lost due to a database connectivity error.
