‎06-14-2006 07:51 AM
Labview - Simple Operator Interface
Labview 8.01
Teststand 3.5
Error -2147467259 occurred at User-defined error code. [Error Code: -2147467259]
Possible Reason(s):
Labview: (Hex 0x80004005) Unspecified error.
Continue
I get this error when I exit the test sequence. The same error if I 'terminate all'.
I don't see this error if I run directly from TestStand sequence editor, so it must be masking the error or handling it differently.
Where is this error message posted? Does anyone recognise the design of the message, etc?
I am pretty new to debugging Labview projects and the only place that I see an error popup is in the Top Level VI
If I click 'Continue' then the CPU usage goes to 100% for the operator interface task and I have to kiil the task to end it.
If I knew where this was in the code, I might be able to handle the error.
Anyone have a place for me to start?
‎06-15-2006 09:16 AM
Hi checkers18,
Are you running the TestStand default simple operator interface or have you made any changes? Have you mass compiled the operator interface directory (C:\Program Files\National Instruments\TestStand 3.5\OperatorInterfaces\User\Simple\LabVIEW) and then recreated the TestExec executable? If not, I would suggest doing this.
Does your sequence file call any LabVIEW VIs? If so, have you tried mass compiling the directory that contains your
Let me know what you have done in terms of mass compiling.
Best Regards,
‎06-15-2006 10:59 AM
‎06-15-2006 11:00 AM
‎06-15-2006 11:52 AM
Hi checkers18,
To force a mass compile, you select Tools >> Advanced >> Mass Compile.
You may want to refer to the KnowledgeBase I Get "OleInitialize Failed Error" if I Try to Connect to Microsoft Access Database because your issue seems very similar.
Also you may want to consider using the Microsoft Jet 4.0 Provider instead of the ODBC driver if this is your case. I found that in general this path to use a Jet database is faster and tends to have fewer problems.
Also try and run our database example to see if you have problems. This example is located at C:\Program Files\National Instruments\TestStand 3.5\Examples\Database.
Let me know what happens!
Best Regards,
