Display LV cluster element value as an expression
I have a custom step type with a VI that has a cluster as input. I would like to display the value of a particular element of the cluster in the description of the step. I know how to get the value of other data-types with the expression
Step.TS.SData.ViCall.Parms["Parameter Name"].ArgVal
Since "Parameter Name" will be a cluster in my case, I can't find how to retrieve the value of a element.
(3,004 Views)
Accepted by GoKu25
Hey,
You can reference the elements in the cluster using the ArrayClusterEls[] property. Your line will look something like this:
Step.TS.SData.ViCall.Parms["ClusterName"].ArrayClusterEls[ElementIndex].ArgVal
For example, my code module has a cluster argument called Cluster with a numeric and boolean control.
The below returns the numeric value (index 0):
Step.TS.SData.ViCall.Parms["Cluster"].ArrayClusterEls[0].ArgVal
The below returns the boolean value (index 1):
Step.TS.SData.ViCall.Parms["Cluster"].ArrayClusterEls[1].ArgVal
Hope this helps.
Nico
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(2,983 Views)
Thanks Nico,
 When I insert the custom step, values are displayed in the description for
1. Enum input
2. Numeric/Boolean/String inside a cluster
But the value of an Enum inside a cluster is not visible right away. When I change the Enum value, it appears in the description. Do you maybe know why?
(2,969 Views)
Hey,
Not sure why this might be, sorry. My inkling would be that the property is not updating until you go and open the cluster elements.
But that's a guess.
Nico
Nico
Systems Engineer
(2,945 Views)
