11-07-2005 07:23 AM
11-07-2005 08:01 AM
Hi Steffen,
Usually there is at least the Test UUT entry point visible, with the SinglePass entry point enabled/disabled via the user priviledges. There shouldn't be any difference between the operating system.
Do you get the same fault if you run with the default CVI OI.
Is it possible to post your users.ini file.
Regards
Ray Farmer
11-07-2005 08:28 AM
