NI TestStand
Executing any sequence in Testand 3.1 says 'TestStand API 3.0' was not found.
I have installed TestStand 3.1 but there seem to be a problem with the software. If I try to run any example sequences it gives me the following error.
Details: The type library information for 'TestStand API 3.0' was not found.
Make sure the server is registered with the system.
Error Code : -18351; An error occurred reading an ActiveX Automation server type library.
Location: Step 'Send Model State Message: 'Initializing'' of sequence 'Single Pass' in 'SequentialModel.Seq'
 I had 2.0 on the system earlier and then 3.0 . 3.0 was almost immediatley removed(without using) and replaced by 3.1.
I have windows2000 professional in my laptop. Incase you have come across an issue like this please help.
(3,453 Views)
did you install the Teststand to the same directory or are they in the defaults eg TestStand2, Program File\National Instrument\ TestStand3.0 etc.
Ray Farmer
Regards
Ray Farmer
(3,447 Views)
I uninstalled 3.0 and then manually deleted the folder Program Files\National Instruments\TestStand3.0
Also there was nothing from 2.0 installation.
After this I installed teststand 3.1.
Sumit
(3,439 Views)
Hi Ray,
I was able to fix the problem.
The type libraries and other registrations won't happen because of certain permissions in regedit which would have been thrown out of gear by some previous installations. In my case it happened due to crystal reports that was being used by the user who had this laptop assigned to him
http://groups.google.co.in/group/microsoft.public.vstudio.setup/browse_thread/thread/d24b6a39139462b...
iled+with+error+8002801c&rnum=1&hl=en#6b3bdaa8b193c90e
You can read more on the fix on the above link. How I could trace the problem to this link was because in my case also no type libraries and dlls were getting registered.
Thank you so much for your help.
(3,431 Views)
