NI TestStand
Expression.Evaluate() - how to use it with propertyobject?
I code in a process model callback and would like to evaluate an expression with the Runstate.Caller context.
I found the method
Expression.Evaluate ( evaluationContext, evaluationOptions = EvalOption_NoOptions)
This is exactly what I need. However, if I have a CallingStep.Expr, which is a expression, I can't access the Evaluate() function. It is not available, only the PropertyObjects functions are.
How can I cast it to be an Expression so I can access the function Evaluate?!
I though I could do:
Runstate.CallingStep.Expr.Evaluate(Runstate.Caller, 0x0)
This would return the expression evaluated in the caller context as a PropertyObject.
But it's not the case, I'm missing something so TS know Runstate.CallingStep.Expr is an Expression... even if I add it to Watch panel, it shows it's an expression...
Thank you.
(4,600 Views)
Accepted by MatLaroche
Try to use RunState.Caller.AsPropertyObject.EvaluateEx(xxx)
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,592 Views)
Thanks, I didn't though of do it this way.
This is one way to achieve it, by doing something like:
Runstate.Caller.AsPropertyObject.EvaluateEx(RunState.CallingStep.TS.CustomResults[1].Name, 0x0).GetValString("", 0x0)
This retrieves the string representing the additionnal result[1] name of my step, which is an expression using local variable in the sequence.
Thanks j_dodek.
If anyone would like to also add a comment about using Expression.Evaluate() properly or an example, it would be appreciated.
(4,589 Views)
Hi Mat,
Just for more understanding
you wrote:  I'm missing something so TS know Runstate.CallingStep.Expr is an Expression
Is this your "Expression" a Statement step Type ?
Or is your "Expression" in every Step in Pre/Post/Status or other in stuff
Could  you provide a screen shot that descripes what you are looking for.
I do not understand it.
Regards
Juergen
--Signature--
(4,569 Views)
I have an object of type Expression (from what I understand and from what the watch panel is showing) and I was expecting to be able to use the Evaluate() function.
Expression.Evaluate(seqContext, options)
But it seems that it's a propertyobject because only the function of this type are available.
I've attached a screenshot. Thank you.
(4,565 Views)
The Expression type in the API is not the same as the Expression type of a PropertyObject.  The Expression PropertyObject type really is just a "labeled" string that lets you know it's supposed to be an expression.
To create an API Expression Object, you need to call Engine.NewExpression.
(4,560 Views)
