FTP Problems with linux ftp server
I have a problem trying to get a file via FTP. The FTP server is in an embedded linux system, getting the file manually via FTP is no problem, but from TestStand I get the following error:
Failed to upload file '/opt/log/sislog.log'.
Check if remote and local path exist and have read and write permissions respectively.
The system cannot find the path specified.
error. I know the file is there, permissions are given. So I tried the other way around, and tried to download a file called "mysislog.log" to that directory and upload it again. I get the same error, but when I telnet to the LUX machine, I see that he has a file in that directory, but the file is called "\mysislog.log" - So I think TestStand put the last backslash into the file name and therefore the file cannot be loaded.
Here the directory listing of the LUX machine:
root@FCM2001-A2-03-37-4A:/mnt/exp0/opt/log > ll
-rw-r-----    1 root     root            0 Apr 16 08:51 \mysislog.log
-rw-r--r--    1 root     root       111219 Apr 16 08:41 syslog_0.log
-rw-r--r--    1 root     root       262096 Apr 13 11:52 syslog_1.log
-rw-r--r--    1 root     root        35503 Apr 13 11:53 syslog_error_0.log
Any ideas?
(5,560 Views)
Accepted by paicolman
Unfortunately, this is a known issue that will be fixed in a future version of TestStand (though I don't know which future version). The FTP step was designed for LabVIEW RT.
The workaround is to call a code module that performs this ftp upload, perhaps using an ftp program.
Cheers,
Cheggers
Sascha
(5,529 Views)
...thought so, thanks for the feedback!
(5,522 Views)
the problem is:  teststand ftp can't be set as passivemode
弟兄们:ts的ftp不能设置为passive模式。
(4,200 Views)
