Format one digit number into two digit numbers
I encounter a typical problem that consists in formatting all one digit numbers 1 2 3 4 5 6 7 8 9 to 01 02 03 04 05 06 07 08 09.
I have read str(  func without finding good format option.
What is the easiest way to do this job ?
Thank you
Message 1 of 8
(6,824 Views)
How do you create the string "1 2 3 4 5 6 7 8 9" ?
where does it come from ?
otherwise a .net step on RegEx will provied desired behaviour
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 8
(6,817 Views)
From Date function, I got 1 or 2 or 3 or 4 or 5 .....number that I convert to string with str( func.
How can I format 1 or 2 or 3 to 01 or 02 etc.....
Message 3 of 8
(6,811 Views)
I would do it this way:
Locals.nSecond = some where from Date()
Locals.strSecond = (Locals.nSecond < 10 ? "0" : "" ) + Str(Locals.nSecond)
Hope that helps
Juergen
--Signature--
Message 4 of 8
(6,806 Views)
Great Thank you !
Message 5 of 8
(6,803 Views)
Accepted by niva
Here's an even simpler way:
Locals.string = Str(Locals.number, "%.2i")
Message 6 of 8
(6,797 Views)
Hi Doug,
it seems it is time for me to read Kernighan & Ritchie once again Smiley Very Happy
Thanks for pointing out!
Regards
Juergen
--Signature--
Message 7 of 8
(6,790 Views)
To get a better idea of the formats that TestStand supports, you can use the numeric format dialog (on a number variable). The dialog will tell you what the format string is for the options which you select.
-Doug
Message 8 of 8
(6,753 Views)
