NI TestStand
Get MenuGroupName of Currently Running Step(C#)
I'm trying to get information about the currently running Step.  For example I can get it's status by doing the following (executed when a trace UImessage event is sent):
e
.uiMsg.Thread.GetSequenceContext(0, out frameId).AsPropertyObject().GetPropertyObject("RunState.Root.Step", 0).GetValString("Result.Status",0);
How Would i go about getting information about the current step's StepType?  So say I wanted to get its MenuGroupName.  How would I go about doing so?
(3,122 Views)
<Step>.StepType.MenuGroupName
(3,118 Views)
Can you elaborate a litte James:
I've Tried:
e
.uiMsg.Thread.GetSequenceContext(0, out frameId).AsPropertyObject().GetPropertyObject("RunState.Root.Step.StepType.MenuGroupName", 0).GetValString("",0);
or
e
.uiMsg.Thread.GetSequenceContext(0, out frameId).AsPropertyObject().GetPropertyObject("RunState.Root.Step.StepType", 0).GetValString("MenuGroupName",0);
But it just doesn't seem to work.
(3,115 Views)
Most API properties are just plain ActiveX properties and are not also dynamic PropertyObject sub-properties. Even some of those that are have different undocumented property object names. Thus you can't access API subproperties in the lookup string you pass to GetPropertyObject.
Try <context>.Root.Step.StepType.MenuGroupName. I don't think you need to call AsPropertyObject or GetPropertyObject.
(3,101 Views)
