How can I paste an image (chart plot) into excel?
I am using Report Generator took kit to put the data I want and where I want into a specific excel file.  However, I would also like to import the image from a strip chart as well.  I figured out how to export it to the clip board but I don't know how to paste it into excel.  Any ideas?
(3,278 Views)
Accepted by topic author Brad_Henry
Hi Brad,
You may have better luck posting in the LabVIEW forum.
If you save the image to a temporary file, you could then import it to the report:
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,272 Views)
It took me a bit to find everything in the palettes but once I did, it worked perfectly.
(3,254 Views)
