12-08-2011 01:26 PM
I am using Report Generator took kit to put the data I want and where I want into a specific excel file. However, I would also like to import the image from a strip chart as well. I figured out how to export it to the clip board but I don't know how to paste it into excel. Any ideas?
Solved! Go to Solution.
12-08-2011 06:17 PM - edited 12-08-2011 06:18 PM
Hi Brad,
You may have better luck posting in the LabVIEW forum.
If you save the image to a temporary file, you could then import it to the report:
12-11-2011 01:41 PM
It took me a bit to find everything in the palettes but once I did, it worked perfectly.
