NI TestStand
How do I change the function of the Run button?
I recently got a new hard drive and had to install all of my National Instruments software Smiley Sad
Now, the Run button in TestStand only runs the selected sequence.  How do I change it back to Single Pass execution of the process model and MainSequence?
(3,344 Views)
Accepted by topic author jaime_c
Right Click on the run button and choose Customize...
Now Click on the Commands tab and click the Rearrange Commands button.
Click the radio button next to Toolbar: and choose Debug from the dropdown next to it.
Select the Command with the Green Arrow and click the Delete Button.
Now click the Add button and select Execute under Categories:
Under Commands: scroll until you find the one you desire.  In this case Second Execution Entry Point.  You will have to repeat the add for other buttons.
Highlight the one you want and click OK.
Click Close and Close when you are finished.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,341 Views)
