How do I set the cursor in the text response of a message box
I am using TestStand 4.1.1. During testing I need to scan in some data from the operator.
I am using a message popup with the text response box enabled. My problem is the cursor does not automatically appear in the text box at run time. I don't want to have to place the mouse in the box each time.
Is there someway to set the cursor to automatically be in the text box.
Don1.
(3,780 Views)
Accepted by ShaneDonn
You have to make the Response Box the active control. You will find the 'Active Control' control in the main tab of the Message Box setup properties window.
Regards
Ray Farmer
Regards
Ray Farmer
(3,773 Views)
Works great.
Son1.
(3,762 Views)
