How to convert into time format from Seconds() function
I used the seconds() function to get the time when I ran the TestStand sequence. How do I convert this number of seconds into a hr:min:sec format?
(4,345 Views)
Hi sportsguy99
Does Time() give you what you need?
Steve
(4,304 Views)
Yes, but I have another question. I have data coming from the Time() function and it says the date of 6/1/2017 and the other date I get from a program into a CSV file which I cannot change the format of and it returns a date of 06/01/2017. I try to put a IF statement and have one test if it is less than or equal to, but the 06 is always less than even if they are the same date since the 0 in front. How do I fix this issue? Or is there another way to convert it to work?
(4,296 Views)
Hello sportsguy99, could you check this example? Here output date is formatted to "04.06.2017 18:25:09" format. Thus, you can compare dates, as they'll have the same length.
Sincerely, kosist90
Check out new feature of LabVIEW 2017!
(4,275 Views)
You can use the 2nd parameter of the Str function which set the format of display of the 1st parameter of the function
For example : format ' Str(Locals.Month,"%02d") ' will display the Locals.Month variable with at least 2 digits, adding a zero before if necessary
Regards
(4,271 Views)
