NI TestStand
How to enable keyboard shortcuts for configuration entry point?
Hello All,
    In my process model, I have a configuration entry point sequence (sequence). I can able to select the corresponding entry from the menu bar ie. configure --> options (for eg). Now I need to have a keyboard shortcut for the same. In my case if I press (for eg) ctrl+w, the configuration entry point sequence must be called.
Note - I have to do this using .NET programmatically.
Is there any way I can incorporate this mechanism...?
Arun
(3,085 Views)
Hello Arun,
At this time there is not anyway to customize the keyboard shortcut keys for menu items you add to the TestStand sequence editor.  R&D is looking into implementing this in a future version of TestStand.  I'll pass along your feedback to them, and let them know there are others interrested in this feature.
Kristen
(3,042 Views)
