How to generate automatically sequence files
Thanks to all , indeed, this discussion has helped me to do similar thing for automation of creating sequence using the xls file(where we give all data to be used).
I made use of application activex palettes in labview to do the automate.
Message 11 of 13
(930 Views)
I want to read the test script file, parse and automate the sequence as per the test script in teststand for example my scripting file is in python and coding is in LabVIEW, how I can use teststand to read the test sequence from scripting file and execute the code as per the sequence step sequentiality.
Message 12 of 13
(644 Views)
Hey Anita,
It looks like this is a pretty old forum post. Your post might get more visibility and participation if you were to make a new thread entirely.
Here is the link for that
https://forums.ni.com/t5/forums/postpage/board-id/330
Sam J.
Message 13 of 13
(637 Views)
