NI TestStand
How to get Step names in MainSequence through TestStand only
I have seen a lot of threads already asking similar question, but all of them are using external modules (VIs, C#, etc.)
I am looking for a way to get step names using only local (TestStand) action steps, for example ActiveX modules. For now it would be enough to get step names only in MainSequence callback.
From what I figured out so far the logic should be like this:
1. Get sequenceFile object
2. Get MainSequenceObject
3. Read property -> Number of steps
4. Get reference to all steps
5. Loop through object to read Name property.
(707 Views)
Accepted by luklem
Found a way, but ran into another problem...
Solution:
1. Load sequence file with Engine.GetSequenceFileEx
2. Get MainSequence reference with SequenceFile.GetSequenceByName
3. Get total num of steps with Sequence.GetNumSteps
4. Get reference to each step with Sequence.GetStep & get it's property with Step.Name
5. Unload Step & Sequence modules
6. Release sequence file with Engine.ReleaseSequenceFileEx
Error:
My release sequence file functions does not work for whatever reason (no errors occur, but bool return value is False), hence I can not unload the file. Are there any other steps that I am missing?
(695 Views)
I don't remember, that I have ever executed to what you refer to Step 5.) in this sceanrio
ReleaseSequenceFileEx is crucial as you've already learned
(677 Views)
Would you share your final solution with the community?
(650 Views)
