‎01-20-2025 02:58 AM
I have seen a lot of threads already asking similar question, but all of them are using external modules (VIs, C#, etc.)
I am looking for a way to get step names using only local (TestStand) action steps, for example ActiveX modules. For now it would be enough to get step names only in MainSequence callback.
From what I figured out so far the logic should be like this:
1. Get sequenceFile object
2. Get MainSequenceObject
3. Read property -> Number of steps
4. Get reference to all steps
5. Loop through object to read Name property.
Solved! Go to Solution.
‎01-20-2025 04:29 AM - edited ‎01-20-2025 05:07 AM
Found a way, but ran into another problem...
Solution:
1. Load sequence file with Engine.GetSequenceFileEx
2. Get MainSequence reference with SequenceFile.GetSequenceByName
3. Get total num of steps with Sequence.GetNumSteps
4. Get reference to each step with Sequence.GetStep & get it's property with Step.Name
5. Unload Step & Sequence modules
6. Release sequence file with Engine.ReleaseSequenceFileEx
Error:
My release sequence file functions does not work for whatever reason (no errors occur, but bool return value is False), hence I can not unload the file. Are there any other steps that I am missing?
‎01-20-2025 05:35 AM
I don't remember, that I have ever executed to what you refer to Step 5.) in this sceanrio
ReleaseSequenceFileEx is crucial as you've already learned
‎01-23-2025 03:32 AM
Would you share your final solution with the community?
