How to programmatically modify PassFail DataSource
I add programmatically a PassFail Step to a TestStand sequence (4.0), but I don’t find the way to modify programmatically the parameters 'DataSource'.
If someone can help me, by advance thank you.
Romuald
(4,472 Views)
Step.DataSource = False  or Step.DataSource = True.  Put this in the pre or post expression.
Is there something specifically that you want to set it to?
jigg
CTA, CLA
testeract.com
(4,471 Views)
I’m a beginner with testStand, maybe I 'm not in the good way.
I parse a file with testStand for create a new testStand sequence. I add to the new sequence a new step for compare the read value to an expected value.
I don’t find the way to programmatically modify DataSource, I would like to add for example: “Step.Result.PassFail=(Locals.readValue==Locals.ExpectedValue)”
I hope, my explanations are clear.
(4,469 Views)
Accepted by Romuald123
You will most likely need to set it using the API.  Something like this:
Locals.PassFailStepReference.AsPropertyObject.SetValBoolean("Result.PassFail", 0, Evaluate(Locals.readValue == Locals.ExpectedValue))
Or just set your DataSource:
Locals.PassFailStepReference.AsPropertyObject.SetValBoolean("DataSource", 0, "Locals.readValue == Locals.ExpectedValue")
the second option might be a better option.
jigg
CTA, CLA
testeract.com
(4,461 Views)
It works with SelValString.
Thank you for your help 🙂
Romuald
(4,453 Views)
