How to set 'Initial Response String' of Popup Message?
There is no 'Browse...' option for the Initial Response String of Popup Message. I' m looking for a solution to fill in a string variable.
I tried the following as PreCondition:
Step.Result.Response=Locals.MessagePopupResponse
but this doesn't work!
Any suggestions?
Sunny
(4,035 Views)
Hi Sunny,
Try and use the pre-expression built-in property for the step to assign a value to this step property at run time.
Hope this helps,
Nick
(4,035 Views)
Hi Nick,
Sorry, i already used Pre Expression and not PreCondition as mentioned in my question, this
doesn't work!
Sunny
(4,035 Views)
Hi Sunny,
The variable you need to set is:-
Step.DefaultResponse
Hope this helps,
Nick
(4,035 Views)
Hi Nick,
Now it works!
Sunny
(4,035 Views)
