Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
IS Test stand support Code written in VC++ ?..IF SO How to integrate with Test Stand
sharanu.dambal@
geind.ge.com
Member
05-03-2004
10:11 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
0
Kudos
Message
1
of 3
(3,064 Views)
Reply
Re: IS Test stand support Code written in VC++ ?..IF SO How to integrate with Test Stand
Ray.R
Knight of NI
05-03-2004
02:04 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yes,
You can select C/C++ in the sequence adapter. Typically, you call library functions in the dll.
It is selectable in the pull-down menu from the TestStand editor (located near the center of the menu screen at the top of the editor).
JLV
2
Kudos
Message
2
of 3
(3,064 Views)
Reply
Ray.R
Knight of NI
05-03-2004
02:07 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If you have LabWIndows-CVI, you may also look at these threads: (may be useful for TestStand)
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000003C1F0000&UCATEGORY_0=_318_&UCATEGORY_S=0
0
Kudos
Message
3
of 3
(3,064 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
