Import excel file using TestStand not using LabVIEW file
I'm trying to import excel file just using TestStand based on example below and so on.
http://www.ni.com/example/30318/en/
I want to read and write excel and put into Variables such as arrays, but just show errors.
Is there any other examples that I can see?
Googling and ni.com but not sufficient yet.
Look forward to your knowhow.
Have a good day.
Best Regards,
(3,043 Views)
 What version of TestStand are you using? In TestStand 2016, if I am not mistaken, Property Loader step type supports loading of parameters from the Excel file. Did you check that, please?
(3,013 Views)
