NI TestStand
Introduction to the SCOPE Step Type in TestStand
Hello! I am new in NI TestStand and like to add a "SCOPE" Step Type in a Test - Programm. Can anyone give a short introduction how i can use this step type ? at first, i set a frequency and the following step should appraise these frequency by the scope. greetings patrick
(3,941 Views)
There is a shipping example called IVIStepTypes.seq. In there, there is a couple of IVI Scope steps. The scope is initialized and then two channels are configured. There is also a read waveform step but you can easily change this to return a frequency measurement to a TestStand variable. You would add a TestStand numeric limit test in order to evaluate the returned frequency.
(3,935 Views)
Thanks Dennis, this was very helpfully for the first step.
At next, i like to appraise the measured values, so that this values, like amplitude etc., are at the Test - Report.
Is there a chance to get this measurement values?
Greetings,
Patrick
(3,910 Views)
Accepted by patrick1988
Hi Patrick,
have you ever looked into the step Variable ?
Hope this helps
Juergen
Message Edited by j_dodek on 04-22-2008 04:09 AM
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,891 Views)
"You would add a TestStand numeric limit test in order to evaluate the returned frequency."
(3,873 Views)
