‎07-17-2007 08:40 AM
‎07-17-2007 08:55 AM
What TestStand version are you using and what language are your code modules in?
TestStand doesn't compile anything but it could be loading your code modules if you have set the steps to load dynmanically.
What modifications have you dont, if you use the default OI does this take the same length of time.
Regards
Ray Farmer
‎07-17-2007 10:42 PM
I am using Teststand 3.5. My code module are in Labview. I use the OI of labview.
It takes same amount of time in the default OI also.
My main sequence consists of 46 test steps. Each step calls a sequence. I have configured each step in the main seq to run in a new execution with Single Pass entry point and wait for execution to complete before starting next step.
Regards
Gopal
‎07-18-2007 05:14 PM
