NI TestStand
Lock Step- Dumb Question
Should it look like this?
Message 11 of 19
(1,995 Views)
Your image is showing the Synchronization settings for the Step and would equate to putting a Lock on your Lock step.  I have never done that before and I haven't seen any Lock steps in NI's own Model Support plugins do that.
What process model are you using?
You can easily prove if your 2 LabView steps are being executed by 1 thread at a time by:
  • put a breakpoint on the UpdateBurninData step
  • Run the sequence using process model....and if you are running multiple "sockets" (threads) you should only hit the breakpoint in each socket one at a time.  If you end up seeing all the sockets paused then all threads are could theoretically be trying to run those steps at the "same time".
Message 12 of 19
(1,982 Views)
Are you referring to the first image when you say it equals putting a lock on the step?
This is the situation I am questioning.
Message 13 of 19
(1,970 Views)
Accepted by topic author subsolanus
In your last image.  That setting is the Step - Synchronization settings.  You don't need that and I have never seen it used. In other words, I have never seen a Lock step setting used on a Lock Step; it just seems redundant to me.
If you are running multiple sockets (threads), the first socket to obtain the Lock will continue and prevent the others from running until the lock is released, then the next socket will obtain the lock.
What process model are you using?  Sequential, Batch or Parallel?
Message 14 of 19
(1,964 Views)
What is happening overall is that when other sequences are running (everything is multithreaded, several UUTs running in parallel), I get run Time Error pop ups where the error statement says that a database file cannot be written to because it is locked.
This pops up in the middle of a random sequence where the database isn't even being used.
It makes me think that in two other threads, the database is trying to be written to and the database write process is not locked properly. The database provider is MS JET.
This occurs randomly every few days.
Message 15 of 19
(1,962 Views)
What process model are you using?  Sequential, Batch or Parallel?  Are you spawning your own threads or letting TestStand handle it via the process model? Or are you running the sequence  from a custom application using TestStand API?
Message 16 of 19
(1,956 Views)
So the checkbox is there to provide a lock function to some other step besides a Lock. Correct?
I am very new to TS, obviously.
Message 17 of 19
(1,950 Views)
I don't know how the threads are being generated. That is in another sequence I haven't looked at yet. I will check. These sequences were written using the Sequence Editor.
Message 18 of 19
(1,949 Views)
Yes, each "Step" type has a built-in option to lock.  The "Lock" Step, because it is a step, also has the built-in option to lock.
Message 19 of 19
(1,936 Views)
